How to combine the polygon with same attribute
5710
8
07-18-2019 02:40 AM
MRC
Hello everyone, I have a shp with includes the table with field QUY_HOACH, The table data included:
CCC- ĐẤT CÓ MỤC ĐÍCH CÔNG CỘNG
ODT- ĐẤT Ở TẠI ĐÔ THỊ
then I want to combine objects close together and the same attributes together
For example, if the data is ccc then all the data that is ccc close together will automatically merge together...
Initial results
And the result
Because there are so many polygons, I can't do it manually, hopefully everyone could help me  which tool can automatically do this job.
i have attached the data here for your references...
sorry for my bad english.
Thanks everyone
DanPatterson_Retired
Dissolve on your attribute field looks like it might work
Dissolve—Data Management toolbox | ArcGIS Desktop
You might have to follow that up with a
Multipart To Singlepart—Data Management toolbox | ArcGIS Desktop
if some of the polygons were a combination of adjacent and non-adjacent polygons prior to the dissolve
MRC
Thank you very much Dan Patterson
it's work for me...
Egge-Jan_Pollé
Hi Havan Cong‌,
I have had a quick look at your data (see screen captures below).
You could use the following tools to accomplish what you want:
  • Dissolve - Aggregates features based on specified attributes.
  • Multipart To Singlepart - Creates a feature class containing singlepart features generated by separating multipart input features.
The first step will combine all features base on the content of the field QUY_HOACH and will reduce the number of records from 1,126 to only 11. In the second step you split these 11 multipart objects into 852 singlepart features.
Does this solve your issue?
Best regards,
Egge-Jan
MRC
Thank for your advice Egge-Jan Pollé, i will follow for your suggestion!
I am very thankful that you are considering my problem
MRC
Could you explain for me these parameters? thanks
create multipart features should be unchecked since it would defeat the purpose of using the Multipart to singlepart tool.
If you plan to do any 'counts' of your data and have multipart features you will get wrong answers.
If a property owner has 5 properties but they are dissolved by attribute on owner, a count of how many properties the individual has would yield "1"... yes 1 multipart feature rather than 5 properties.
Similarly with unsplit lines, although it can be useful, it can also have its own issues.
In short, don't leave them checked until you have read the implications from the help files.
MRC
Thank you very much
Your question remains open.  Was it answered?
