'Failed to parse' error in Feature Report
6637
7
07-01-2019 09:11 AM
AprilChipman
I am unable to create reports since the upgrade. Did any of the report "coding" change with the upgrade?
BrandonArmstrong
Thank you for uploading those files.
After replacing single quotes with double quotes, in the feature report syntax for select one questions, you should be able to proceed without error.
For instance, ${OldLightType|selected:'1' should be ${OldLightType|selected:1}
Please try this out and let me know our results.      Feature report templates—Survey123 for ArcGIS | ArcGIS
Best,
Brandon
BrandonArmstrong
Hi April,
Would you be able to provide your XLSForm and Micorosft Word document used for the report?
You can upload here or send to me at [email protected]
Brandon
AprilChipman
I've attached both the MS Word report and the MS Excel xls form.
BrandonArmstrong
Best,
Brandon
AprilChipman
Yes! This fixed it - thanks Brandon!
ChrisYoung2
I am having a similar problem. See screenshot below. How can I fix this?
AprilChipman
Chris, you will need to edit your Word document template and change the single quotes to double quotes.
April
ChrisYoung2
Thank you. That did work. It would be nice if whenever new versions come out, a new comprehensive code list or changes in coding was also created and published somewhere. The brief document that came out with this new version did not seem to mention anything about this.
An Accredited land trust
Chris Young
Stewardship & GIS Coordinator
Columbia Land Conservancy
49 Main Street
Chatham, NY 12037
518.392.5252 ext. 221
[email protected]<mailto:[email protected]>
www.clctrust.org
Conserving rural landscapes.
Connecting people to the land.
