problem with intersect
2476
5
06-27-2019 04:49 AM
JohannesBierer
This code leads to a error message:
Object: Error in executing tool
Any ideas why? Might be something in line 17?
# -*- coding: cp1252 -*-
import arcpy
InFc = r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Geodaten.gdb\data\graeben_breitlhohloh_Prioritaer"
field = "OBJECTID"
InContour = r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Geodaten.gdb\data\Hohlohbreitl_Contour_50cm"
try:
    with arcpy.da.SearchCursor(InFc, field) as cursor:
        for row in cursor:
            print(row)
            scl = "OBJECTID = {}".format(row[0])
            print scl
            inFcLayer = arcpy.MakeFeatureLayer_management(InFc, "lyr_{}".format(row[0]), scl)
            inFeatures = """ ["{}", "{}"] """.format(inFcLayer, InContour)
            print inFeatures
            outFeature = r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a_{}".format(row[0])
            arcpy.Intersect_analysis(inFeatures, outFeature, "ALL", "", "POINT")
        del cursor
except Exception:
    e = sys.exc_info()[1]
    print(e.args[0])
DanPatterson_Retired
x = r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a"
arcpy.Intersect_analysis(inFeatures, x, join_attributes="ALL", output_type="POINT")
Try overt assignment of the 'optional' parameters, so you can skip the 2nd last one.
barring that... make a gdb in c:\temp and direct the output there to see if there is something wrong with the full path or the ... .gdb\data portion of it
a = 'first'
b = 'second'
c = ' ["{}", "{}"] '.format(a, b) # ---- option 1
c
' ["first", "second"] '‍‍‍‍‍‍
c = " ['{}', '{}'] ".format(a, b)  # ---- option 2
c
" ['first', 'second'] "‍‍‍‍‍‍‍‍‍‍‍
You syntax checked, but the two options to derive single vs double quotes can be simplified to.
But you might have problems depending on whether row[0] returns single or double quotes
r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a_{}".format('field')
'R:\\Karto\\Bierer2019\\Kaltenbronn_DGM\\shapes\\Zwischendaten.gdb\\data\\a_field'
r'R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a_{}'.format("field")
r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a_{}.format("field")
.... doesn't complete
Get rid of the try-except stuff to test to see if a syntax error will be returned
JohannesBierer
Without try except I get the following message?
  line 22, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\analysis.py", line 289, in Intersect
    raise e
RuntimeError: Object: Error in executing tool
JohannesBierer
For:
outFeature = r"R:\Karto\Bierer2019\Kaltenbronn_DGM\shapes\Zwischendaten.gdb\data\a"
arcpy.Intersect_analysis(inFeatures, outFeature1, "ALL", "", "POINT")
It is the same error message
JohannesBierer
If I write it like this it worked
arcpy.Intersect_analysis([outFG, outFC], outFeature, join_attributes="ALL", output_type="POINT")
