river merge problem in basin processing using ArcGIS via the Hec-GeoHMS extension
1698
06-14-2019 02:25 AM
sofiasarchani
Hello! I use the Hec-GeoHMS 10.1 extension in ArcGIS 10.1. After merging 65 subbasins into one basin, I'm trying to river merge all individual streams unsuccessfully. The message from the above action is: disconnected rivers or rivers meeting at confluence can not be merged. I notice that all individual streams are meeting at a confluence. I would like to ask if I'm doing something wrong or if there is an alternative methodology in order to merge all rivers in one. Thank you in advance.
KurtisBaron
Sofia, you can manually delete river segments that will not be modeled as routing reaches through an edit session.  I think you'll only use River Merge where you'll end up with one single continuous line that does not branch.  Hope this helps.  Kurt
