Modify the environment-settings by using arcobject c#
1702
05-15-2019 01:39 AM
DharmaRajan
Hi All,
How to modify the existing/active environment-setting by using arcobject C#(For example: ProcessingExtent = 'as specified below'). Kindly suggest.
GKmieliauskas
Hi Dharma,
If you mean GeoProcessor using, then before calling Execute method you can set environment variables using SetEnvironmentValue method. Sample here:
https://idea.isnew.info/how-to-use-the-geoprocessor-using-arcobjects.html
DharmaRajan
Hi Gintautas Kmieliauskas,
No.
I want to update the existing environment variables. So that all the GeoProcessing tools (invoked through code or manually) within that particular session will execute based on that.
