Failure to parse incoming JSON - Event Not Matched
6017
03-15-2019 07:56 AM
ChaseBarnard
I'm attempting to read in a generic JSON array containing AVL data via UDP Socket.  The array is basically as follows:
{"id":7219,"p":4388,"d":"06802","u":102,"r":"F-E31","s":"R-I","x":0,"c":"","t":"2019-03-15T10:06:50","rack":0,"l":35.918,"g":-79.03748,"z":137,"h":81,"m":14,"a":5}
I continue to get an "Event Not Matched" warning followed by a "Failed to parse the incoming JSON" error for every incoming record.  It seems like the GeoEvent definition file is correct, but I must be missing something.  I've attached screenshots of the input connector configuration, the GeoEvent definition, and the error log.  Any suggestions?
Chase
ChaseBarnard
I seem to have resolved the issue.  I went back to square one and recreated all the components.  The key was to leave the JSON Object Name: parameter blank on the input connector. Even though I was using what seemed to be a legitimate field, it was preventing GES from creating the initial auto-generated GeoDefinition file.  Once I did that, GeoEvent Server began processing records.
ChaseBarnard
BrianBaldwin
Thanks for posting this and your answer Chase! Just helped me with the same issue!
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
Nadia_Matsiuk
Hello!
I have a similar problem. Does anyone know why it's often get this strange error with JSON Object Name option? Maybe this is some kind of bug? Very interesting.
Thanks.
