Trying to get this to work: Package used to build ESRI Web App Builder Apps for production.
5797
18
03-11-2019 02:45 PM
IanPeebles
I am trying to get this package to work, but having difficulties getting started.  I found out a new way on how improve the performance of WAB applications.  I was referred to this documentation:
https://github.com/gbochenek/esri-wab-build/
I see the steps to follow, but not able to get these commands to run in command prompt.  Which command prompt should I be using?
Are there any screenshots that somebody can provide, so I can follow along?
Would love to give this a try
My web app builder is installed at: C:\GIS\arcgis-web-appbuilder-2.11\WebAppBuilderForArcGIS
Any help will greatly be appreciated.
Tags (1)
RobertScheitlin__GISP
Have you installed the prerequisites?
Requirements:
  • Bower (validated with 1.8.0) installation : npm install -g bower
  • Nodejs (validated with 6.9.4)
  • Java 7 or greater
  • Git
having WAB does not mean that you actually have node installed.
IanPeebles
Hello Robert,
I did install Nodejs yesterday afternoon.
Nodejs
Do I need to go to the following location to get Bower?  is that a local install as well?
https://bower.io/
I just ran the command:
Bower
I do have Java version 8 installed.
Java Version
I am not sure what Git is
I guess when I get all these components installed, I go to the command prompt?  That is where I am getting stuck.  Install instructions for the pre-requisites would be useful.
Thank you for your help.
Ian,
  Go to the windows start button and the "Node.js" folder and "node.js command prompt"
For bower go to the command prompt above and enter "npm install -g bower"
IanPeebles
Robert, I have the nodejs command prompt:
Command Prompt
In the regular CMD prompt, I did install Bower:
Bower Install
So now do I go to the nodejs command prompt?
Just like I said in my last reply:
IanPeebles
OK, thanks for the help so far, this is a learning experience and something new for me.  Trying to document this as I go.  So when following the steps
1. Navigate to the application to be built (I go through the file structure):
There is no package.json, yet.
2. Create a project.json file (if one does not exist): npm init
or do I create the file manually like in a notepad++?
Do npm init and it will walk you through creating one.
IanPeebles
OK, this is where I am getting stuck.
Ian,
   The window that you are showing in your screen capture is Not the "node.js command prompt"... that is the "Node.js" link you clicked on.
