Missing all services after upgrade
3220
6
01-25-2019 10:00 PM
DanGriffin
I've upgraded form 10.5.1 to 10.6.1 and I've lost all map services, even the default world cities.  I've confirmed that the site directories are set up correctly and the files still exists in the same location as before. Directory permissions seem correct.  Not sure what else to check?
DanGriffin
Licensing issue
ReidWebb
How can I verify if the cause is a licensing issue?
DanGriffin
In Manager go to - Site - Software Authorization and look at Licensed Role:
ReidWebb
Licensed Role:  Image Server
Expiration Date:  Never
Software Version:  10.6.1 (build 9270)
Looks authorized to me, correct?
DanGriffin
You're missing the ArcGIS Server License.  This is how it looks for me:
Licensed Role:  GIS Server Advanced, Image Server
ReidWebb
I figured it out. When you run the ArcGIS authorization utility, it shows you the Authorization Number (ECPXXXXXXXXX) number that it reads from the provisioning file.
The problem was that, by default, the utility was reading the wrong Authorization Number from the provisioning file. It was reading the Image Server Authorization Number to authorize Server instead of the Server Standard Authorization Number. Once my GIS POC sent me the screenshot showing the two different numbers, I realized what was happening and changed the ECP number to match Server instead of Image Server.
Thank you guys!
