Help using PointGeometry with SelectLayerByLocation
6755
19
01-11-2019 11:36 AM
ZoltanSzecsei
The following code fails:
pg = arcpy.PointGeometry(vert,'None',True)
arcpy.SelectLayerByLocation_management("hgt_feats", "WITHIN_A_DISTANCE_3D", pg, 0.005, 'NEW_SELECTION')
with:
File "Z:/Projects/Development/python/ToGround/ToGround.py", line 140, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.6\ArcPy\arcpy\management.py", line 7873, in SelectLayerByLocation
raise e
RuntimeError: Object: Error in executing tool
I'm trying to see if there is an underlying polygon vertex at a specific XYZ location.
I do not need to select the underlying polygon, I just need to know if there is one at that location
Any help would be appreciated.
Regards and thanks,
Zoltan
Tags (1)
DarrenWiens2
Try specifying a spatial reference on your PointGeometry, even if it is unprojected.
DanPatterson_Retired
PointGeometry—ArcPy classes | ArcGIS Desktop  intersects perhaps, if you want to work with arcpy geometry objects
The Select Layer By Location—Data Management toolbox | ArcGIS Desktop are using feature layers
ZoltanSzecsei
Hi Dan
I'll take a deeper look at the Point Geometry classes - but I did find plenty of examples using Geometry with SelectLayerByLocation, so I was wondering why my forehead has square indentations and my keyboard broken 🙂
Thanks and keep well,
Zoltan
DarrenWiens2
ZoltanSzecsei
I have - and have also set arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(blah blah)
It is a projected system with metric coords
Dan's put me on to using geometry methods - now that I take a deeper look, it is a better way to solve my particular issue - I'm just  busy wrapping my head around using disjoint/intersect/whatever...........
ZoltanSzecsei
AAaargh! Yes! (Darren says: Try specifying a spatial reference on your PointGeometry)
I override it with 'None', so that negates my env setttings.
I've now added the Spatial Reference into the arcpy.PointGeometry() and it is now working.
Big thanks Darren 🙂
Zoltan
JoshuaBixby
MVP Esteemed Contributor
You didn't override it with None, you just created a point geometry without one.  In your original code, I assume vert is an ArcPy Point, and ArcPy Points don't have spatial references so there is nothing to override.
ZoltanSzecsei
Actually (psychologically) I did "override" it.
If one sets and env to a SRS/CRS, one should be able to assume that all dimension and coordinate related values would be interpreted by ArcGIS to be in the CRS set by the env.
By placing 'None' in a specific command, that (intuitively) explicitly says "override the env requested CRS"
I know this is about symantecs of speach, but I make this point because when ESRI provide certain settings, certain expectations are also "enabled".
HTH
Z
JoshuaBixby
I know what you are saying, and agree, about expectations.  About 1/3 of the defects I log are where the software works but the behavior doesn't agree with documentation.  I don't care which one Esri fixes, either the software or the documentation, but even getting documentation updated has taken multiple versions.  I get fixing software defects takes time, but the slowness up addressing documentation issues has always frustrated me greatly.
Select by Location according to the help files, requires 2 feature layers as input. (A hidden feature of arcpy? )
Zoltan, do you have the example where an arcpy geometry object and a feature layer made it work?
