Forest-based Classification and Regression
4710
13
01-10-2019 03:32 AM
saffeterdogan
Forest-based Classification and Regression tool closing arcgis pro? what is the problem
XanderBakker
Esri Esteemed Contributor
What version of ArcGIS Pro are you using? What type of data? How big is the data that you are using? Did you reach out to Esri Support with this problem? Any error message or is ArcGIS Pro just closing? Does it close directly or does it process a while first? A bit more information would be helpful.
saffeterdogan
I use Arcgis pro 2.2.4.
 I tried it with my own data
program closing there is no eror message
Then ı used this data set it is same program closing
Forest-based Classification and Regression in ArcGIS Pro 2.2
saffeterdogan
it process a while first then closing
XanderBakker
I will have a look later on if I can reproduce the problem with the data you mentioned: California Housing Data (1990) | Kaggle
Can you provide a screenshot of the settings you are using?
saffeterdogan
Prof. Dr. Saffet ERDOĞAN
Harran Üniversitesi
Mühendislik Fakültesi
Harita Mühendisliği Bölüm Başkanı
Web:saffeterdogan.com
e mail:[email protected]
:[email protected]
Adres:
Harran Üniversitesi Mühendislik Fakültesi Harita Mühendisliği Bölümü
Mardin Yolu 22 Km Osmanbey Kampüsü ŞANLIURFA
Tlf : (0414) 318 34 76
Fax: (0414) 3183799
saffeterdogan
I used the same parameters in that tutorial
XanderBakker
The first calculation (training the model based on the housing attributes) worked fine for me:
What data format are you using for the layer daa_shp? I converted mine to a file geodatabase featureclass using the Display XY events option.
saffeterdogan
I used file geodatabase. I have the same problem. I tried it botg geograpgic and projected projection systems Still closing
saffeterdogan
May ı request your file to try in my computer? Thanks
