Add LDAP users via code Portal 10.5.1
2038
12-26-2018 05:59 AM
RoberthSanchez
Hi, i have some problems adding users to my organization in portal 10.5.1, i found this python code to add users using the portal web service /portaladmin/security/users/createUser:
#!/usr/bin/env python
# Requires Python 2.7+
# Demonstrates how to add users to Portal for ArcGIS in bulk
# For Http calls
import httplib, urllib2, urllib, json
# For system tools
import sys, os
# For reading passwords without echoing
import getpass
# Other utilities
import Queue
# Defines the entry point into the script
def main(argv):
    print "This script adds users in bulk into a portal. \n"
    #Get parameters
    parameters = getParametersFromUser ()
    portalURL = parameters['portalURL']
    provider = parameters['provider']
    userName = parameters['userName']
    password = parameters['password']
    inUserFile = parameters['inUserFile']
    #Get user data from file
    usersData = getUserDataFromFile(inUserFile,provider)
    #Create users
    createUsers (userName,password, portalURL,provider, usersData)
    raw_input('Press ENTER to close the script.')
    return
# This function loads all the user data in the input text file into a Python Queue.
# This usersQueue can be later passed to the createUsers function
def getUserDataFromFile(inUserFile,provider):
    usersQ = Queue.Queue()
    keyParams = ['username', 'password', 'email', 'fullname','role','description']
    inFileHandle = open(inUserFile, 'r')
    userCount = 0
    print '...Processing input users file at: ' + inUserFile
    entryCount = 1;
    for line in inFileHandle.readlines():
        userParams = line.split('|')
        userParamDict = {}
        if provider=="webadaptor":
            if len(userParams) == 5:
                for i in range (0,5):
                    userParamDict[keyParams[0]] = userParams[0]  # login
                    userParamDict[keyParams[1]] = ""
                    userParamDict[keyParams[2]] = userParams[1]  # email address
                    userParamDict[keyParams[3]] = userParams[2]  # name
                    userParamDict[keyParams[4]] = userParams[3]  # role
                    userParamDict[keyParams[5]] = userParams[4].replace('\n','')  # description
                usersQ.put (userParamDict)
                userCount = userCount + 1
            else:
                print ' The format for entry %s is invalid.  The format for enterprise accounts should be <login>|<email address>|<name>|<role>|<description>. \n '% (entryCount)
                raise SystemExit( 'When registering enterprise accounts, the format for each entry is as follows: <login>|<email address>|<name>|<role>|<description>')
        elif provider=="arcgis":
            if len(userParams) == 6:
                for i in range (0,6):
                    userParamDict[keyParams[0]] = userParams[0]  # account
                    userParamDict[keyParams[1]] = userParams[1]  # password
                    userParamDict[keyParams[2]] = userParams[2]  # email address
                    userParamDict[keyParams[3]] = userParams[3]  # name
                    userParamDict[keyParams[4]] = userParams[4]  # role
                    userParamDict[keyParams[5]] = userParams[5].replace('\n','')  # description
            else:
                print ' The format for entry %s is invalid.  The format for built-in portal accounts should be <account>|<password>|<email address>|<name>|<role>|<description>.  \n '% (entryCount)
                raise SystemExit( 'When registering built-in portal accounts, the format for each entry is as follows: <account>|<password>|<email address>|<name>|<role>|<description>')
        else:
            print '   The provider is incorrect. Script ended. \n'
            raise SystemExit( 'The value for the user type is invalid. ')
        entryCount = entryCount +1
        if not ((userParamDict[keyParams[4]].lower()== "user") or (userParamDict[keyParams[4]].lower()=="publisher") or (userParamDict[keyParams[4]].lower()== "admin")):
            raise SystemExit( 'The value for the user role %s in users text file is invalid.  Accepted values are user or publisher or admin. ' % (userParamDict[keyParams[4]]))
    inFileHandle.close()
    # Create users and report results
    print '...Total members to be added: ' + str(userCount)
    return usersQ
# This function connects to the portal and adds members to it from a collection
def createUsers(username,password, portalUrl, provider,userParamsQ):
    print '...Connecting to ' + portalUrl
    token = generateToken(username,password, portalUrl)
    print '...Adding users '
    usersLeftInQueue = True
    while usersLeftInQueue:
        try:
            userDict = userParamsQ.get(False)
            userDict['f'] = 'json'
            userDict['token'] = token
            userDict['provider'] = provider
            params = urllib.urlencode(userDict)
            request = urllib2.Request(portalUrl + '/portaladmin/security/users/createUser?',params, { 'Referer' : portalUrl })
            # POST the create request
            response = urllib2.urlopen(request).read()
            responseJSON = json.loads(response)
            # Log results
            if responseJSON.has_key('error'):
                errDict = responseJSON['error']
                if int(errDict['code'])==498:
                    message = 'Token Expired. Getting new token... Username: ' + userDict['username'] + ' will be added later'
                    userParamsQ.put(userDict)
                else:
                    message =  'Error Code: %s \n Message: %s' % (errDict['code'],
                    errDict['message'])
                print '\n' + message
            else:
                # Success
                if responseJSON.has_key('status'):
                    resultStatus = responseJSON['status']
                    print '\n' + 'User: %s account created' % (userDict['username'])
                    print 'User: %s account created' % (userDict['username'])
        except Queue.Empty:
              usersLeftInQueue = False
# This function gets a token from the portal
def generateToken(username, password, portalUrl):
    '''Retrieves a token to be used with API requests.'''
    parameters = urllib.urlencode({'username' : username,
                                   'password' : password,
                                   'client' : 'referer',
                                   'referer': 'https://domain.com',
                                   'expiration': 60,
                                   'f' : 'json'})
    try:
               response = urllib.urlopen('https://domain.com/arcgis/sharing/rest/generateToken?',
                              parameters).read()
    except Exception as e:
        print( 'Unable to open the url %s/sharing/rest/generateToken' % (portalUrl))
    responseJSON =  json.loads(response.strip(' \t\n\r'))
    # Log results
            message = 'Token Expired. Getting new token... '
        else:
            errDict['message'])
            raise SystemExit(message)
    token = responseJSON.get('token')
    return token
# This function gets gets parameters from the user in interactive mode
def getParametersFromUser():
    parameters = {}
    # Get Location of users file
    inUserFile = raw_input ("Enter path to users text file: ")
    if not os.path.exists(inUserFile):
        print '   File does not exist. Script ended. \n'
        raise SystemExit( 'Input file: %s does not exist' % (inUserFile))
    parameters['inUserFile'] = inUserFile
    # Enteprise logins or built-in accounts?
    userInput = raw_input ("What type of users do you want to add to the portal?  Accepted values are built-in or enterprise: ")
    if userInput.lower()=="built-in":
        parameters['provider'] = 'arcgis'
        print '   Built-in accounts will be added to the portal. \n'
    elif userInput.lower()=="enterprise":
        parameters['provider'] = 'webadaptor'
        print '   Enterprise accounts will be added to the portal. \n'
    else:
        print '   The type of users is incorrect. Script ended. \n'
        raise SystemExit( 'The value entered for the user type %s is invalid.  Accepted values are built-in or enterprise. ' % (userInput))
    # Get Portal URL
    hostname = raw_input("Enter the fully qualified portal hostname (for example myportal.acme.com): ")
    parameters['portalURL'] = 'https://' + hostname + '/arcgis'
    print '   Users will be added to portal at: ' + parameters['portalURL'] + '\n'
    # Get a username and password with portal administrative privileges
    parameters['userName'] = raw_input("Enter a built-in user name with portal administrative privileges:")
    parameters['password'] = raw_input("Enter password: ")
    print '\n'
    return  parameters
# Script start
if __name__ == "__main__":
    sys.exit(main(sys.argv[1:]))
The code work's fine but at the moment of add users the web service return the next message:
"Error 500, Failed to register member xxxxxx (xxxxxx @domain.com). The number of registered portal members is equal to or greater than the number of licensed members"
But all i have is one built-in user (the native portal admin) and one more admin added from LDAP and i have enough licences to add new lvl 2 users, in fact in the organization tab i can see that i have 2 / 5 lvl 2 licences used, so i have 3 to add new users, what i'm attempting to add is a regular lvl 2 "user" role:
  xxx2682|[email protected]|xxx2682|user|test
i have already tried add users directly from the organization tab and i can do it.
Can anyone help me with this? there is any solution?
Thanks.
JeffSmith
Looking at the python code, the provider that is being sent to the portaladmin/security/users/createUser endpoint needs to be 'enterprise' instead of 'webadaptor'.  I'll see if I can get help doc updated to fix this sample python code.  I'm not sure why the error being returned doesn't indicate it is an invalid provider.
RoberthSanchez
Thanks for your response Jeff, i have already tried replacing the provider from "webadaptor" to "enterprise" and i got the same error:
Tried with the built-in option too and i got the same error, so it seems like is something else.
