Adding mobile breakpoint programmatically
2470
6
11-02-2018 07:15 AM
joerodmey
I'm looking to use code to add in the mobile breakpoint into my URLs instead of doing it through my web server. Is this an option?
RobertScheitlin__GISP
Joe,
  In your code just use this:
window.jimuConfig.breakPoints[0] = 410;
Joe,
joerodmey
Just to confirm that would provide the same results as the following:
https://domanin.com/testingApp/?mobileBreakPoint=10
Correct
DDUEDesarrollo_Urbano_y_Ecolog
And the popup window can you modify your view from the mobile device?
thanks
JamesMadden1
I have implemented the above solution but the layout only changes after the the window resizes.  Is there anyway to update the layout immediately after changing the breakpoints?
James,
  Get a reference to the ConfigManager.js and call the _onWindowResize method.
