Filter Widget - Web AppBuilder AGOL- layers is not hidden??
1998
10-17-2018 07:32 AM
AlexP_
Feature service published from ArcMap 10.5.1 to ArcGIS Server 10.5.1, ArcGIS Online, Web Map, Web AppBuilder, Filter Widget.
I am trying to use one layer "turn on" apply while the rest of other layers "turn off or hidden" in filter widget from WAB. It doesn't work. All layers are still "turn on". Am I suppose to set something from Web Map? I am not sure what steps I am missing. Please assist me in this matter.
Thank you.
MichaelVolz
Esteemed Contributor
I am seeing the same issue.  Can you provide the exact steps you used to setup the Filter Widget?  How many layers do you have in your feature service from ArcMap 10.5.1?
AlexP_
layers are published individual from ArcMap 10.5.1. I had group layers but it always crashed instead I used individual. I have 14 layers total in web map and WAB. FYI I am in development stage. The only setting I currently from Web map filter is #1 screenshot. See WAB filter widget #2 screenshot with zoom in apply. I have a sort of workaround to use Visible Range but it is not helpful because you still can see all other layers.
#1 Web map
#2 Web AppBuilder
MichaelVolz
Have you tried using a non-date field to see if that works better?
AlexP_
Yes, I tried but it is the same result.
