Not possible to use the decimal separator (",").
3545
8
09-28-2018 05:28 AM
CristianoGonçalves1
In form created in Survey 123 Connect with decimal field, when accessed by a user by in a web browser, it is not possible to use the decimal separator (",").
Does anyone have any solutions to this problem?
LuisCalderon1
Try "." (period) instead of comma.
Luis
(863) 675-5365
lcalderon@hendrypa.com<mailto:lcalderon@hendrypa.com>
CristianoGonçalves1
already tried and did not work too. But if I write in a text file, copy and paste it in the form field, it accepts the comma.
JoeBorgione
Comma as a 'decimal' separator? That has me confused:
1,75 liters versus 1.75 liters : to me the former is a range between 1 and 75 liters where as  the latter tells me I have one and three quarter liters.
What are you trying to represent?
CristianoGonçalves1
I am trying to represent decimal separator for money used in Brazil, for exemple R$ 2,50.
LuisCalderon1
Latin-American & I believe Europe also.
Luis
(863) 675-5365
JoeBorgione
Most interesting!  Thanks for the explanation!
LuisCalderon1
Sorry, don't know what else it could be.
If no solution found, contact ESRI Support directly.
Luis
(863) 675-5365
FranciscoAndrade1
https://community.esri.com/message/735109-re-how-to-format-display-of-calculated-result-in-survey123...
As per that post, it looks like that functionality is not possible. The post is from 12/08/2017.
