Duplicate existing layout - ArcGIS Pro SDK
2761
09-21-2018 05:00 AM
BorjaParés_Fuente
Is there any method included in the sdk to duplicate a layout including all its elements? I can't find it. I've also tried to go through all the elements of the source layout to insert them into a new one but I don't see it very effective because you would have to use the LayoutElementFactory.Instance.Create method for each of them, and each method has different parametrers.
Thansk in advance.
Borja
CharlesMacleod
This is how it works:
1. Make a new layout
2. Copy the layout to be "duplicated" (this is the Clone method)
3. Replace the layout URI of the copy with the URI of the new layout (in other words, the new layout acts as a placeholder)
4. Set the copy/clone back as the new layout definition
Step 3 is the crucial step. I have posted the code below. I'd recommend running it in the debugger so you can grok what's going on
internal class DuplicateLayout : Button
    protected async override void OnClick() {
      var layoutView = LayoutView.Active;
      try {
        if (layoutView?.Layout != null) {
          await layoutView.Layout.Duplicate();
      catch (Exception ex) {
        System.Diagnostics.Debug.WriteLine(ex);
public static class LayoutExtensions
    public static async Task Duplicate(this Layout layout) {
      if (layout == null)
        throw new ArgumentNullException(nameof(layout), "layout cannot be null");
      var layout_clone = await layout.CloneAsync();
      FrameworkApplication.Panes.CreateLayoutPaneAsync(layout_clone);
    public static Task<Layout> CloneAsync(this Layout layout) {
      return QueuedTask.Run(() => {
        return Clone(layout);
    //Must be called on the QueuedTask
    public static Layout Clone(this Layout layout)
      var layout_dup = LayoutFactory.Instance.CreateLayout();
      var metadata_uri = layout_dup.GetDefinition().MetadataURI;
      var layout_def = layout.GetDefinition();
      var layout_def_clone = layout_def.Clone() as CIMLayout;
      layout_def_clone.URI = layout_dup.URI;
      layout_def_clone.MetadataURI = metadata_uri;
      layout_dup.SetDefinition(layout_def_clone);
      return layout_dup;
public static class CIMExtensions
    public static CIMObject Clone(this CIMObject cimObject)
      var clone = System.Activator.CreateInstance("ArcGIS.Core", cimObject.GetType().ToString()).Unwrap() as CIMObject;
      var stringReader = new StringReader(cimObject.ToXml());
      var xmlReader = new XmlTextReader(stringReader);
      //xmlReader.MoveToContent();
      clone.ReadXml(xmlReader);
      xmlReader.Dispose();
      return clone;
CharlesMacleod
      try {
      if (layout == null)
      return layout_dup;
      return clone;
BorjaParés_Fuente
Hi Charles,
Sorry for the delay. It works perfect!
