VERSION ERROR
1055
09-16-2018 10:33 AM
by Anonymous User
Not applicable
Hello!  I am attempting to use these templates for Citizens to report property damage in Onslow County from Hurricane Florence.  I only added a PARID field to the survey while testing the survey out.  When I initialize the survey it gives me an error.  Any ideas on what is causing it?  I don't want citizens to think the survey is broken. It happens in all 3 browsers (internet explorer, firfox, chrome)
https://survey123.arcgis.com/share/759d43c37ad145168d0d42898c07a52d
Angelia
JamesTedrick
Esri Esteemed Contributor
Hi Angela,
As mentioned in the response on the blog post, remove the calculation version() and property('uri:deviceid') if you want to use this as a web form.
JamesTedrick
Hi Angela,
by Anonymous User
Not applicable
Thanks for the reply!  I ended up re-creating it using Survey123 web design.  Time was short and we needed to put it out quickly.  I will try your suggestion when creating another survey.  Thanks!
