Texas Building Footprints
8652
17
08-08-2018 06:04 AM
SonaSunny
Has anyone had success in converting the Microsoft building footprints data for Texas  to featureclass? I tried several times using the conversion tool box but it keeps on crashing.
George_Thompson
Esri Notable Contributor
Update: I tested importing North Dakota using the JSON to Features GP tool and it worked fine, no crashes.
I would install Pro 2.2.2 and then rested.
--- George T.
George_Thompson
This works: https://www.arcgis.com/home/item.html?id=9da0f8ae5fee45aca11bf77f712884c8
Requires ArcGIS Pro 2.2 and ArcGIS Data Interoperability extension, or the FME 2018 product.
It worked great for me!
--- George T.
SonaSunny
Thank you will try that!
SonaSunny
I don't have the Data Interoperability Extension. I tried to use a trial version of the FME 2018 product but that is crashing too 😞 . Were you able to extract the Texas data ?
George_Thompson
Sona Sunny‌ I was able to do this with Data Interop extension. I did NOT install FME from their site.
BUG-000116435
Performance issue when converting large GeoJSON files.
Release notes for ArcGIS Pro 2.2—ArcGIS Pro | ArcGIS Desktop
The latest patch can be downloaded/installed via the Pro built-in updater or via My Esri. Once installed and retry the workflow, please report back. Thanks!
--- George T.
SonaSunny
It worked!!! Pro 2.2.2 is the Winner! It took  50 min to convert the Texas Geojson file to a File geotabase feature Class. Thank you George for letting me know of the latest patch! I had almost given up on this dataset as FME also crashed and that's when saw your post!
George_Thompson
Thanks for the update! I am glad to hear that it is working for you now.
--- George T.
NicholasBailey
I got this to run and work but when i looked at the attribute table it didn't have shape length or area length? Any idea of what i have to do to get it to import the height attributes?
George_Thompson
There is shape area and length: See for Texas below.
I bet the small #'s are related to the spatial reference of the data.
I do not see any data related to height attributes only the 2D representation of the building footprint.
--- George T.
NicholasBailey
Perfect. I got it to work using the FME workbench. Only problem now is my buildings are in the middle of the ocean near Africa. How did you manage to get it into EPSG: 4326? I cant find that projection anywhere in the ESRI system.
