Open Widget Programatically ( Foldable Theme)
2360
6
08-07-2018 05:25 AM
KrishV
Open a widget from another widget
var widgetCfg = this._getWidgetConfig('Edit');
            var wm = WidgetManager.getInstance();
            wm.loadWidget(widgetCfg).then(lang.hitch(this,function(){
              if (widgetCfg) {
                //sbc = WidgetManager.getInstance().getWidgetsByName("headerController")[0];
                printWidget = WidgetManager.getInstance().getWidgetByLabel(widgetCfg.label);
                if (printWidget) {
                    WidgetManager.getInstance().openWidget(printWidget);
                      PanelManager.getInstance().showPanel(printWidget);
                } else {
                    //sbc.setOpenedIds([widgetCfg.id]);
                    //sbc._resizeToMax();
                    setTimeout(function() {
                        printWidget = WidgetManager.getInstance().getWidgetById(widgetCfg.id);
                    }, 3000);
Please let me know, how I can open Edit Widget in Foldable Theme.
Regards,
Krish
Tags (1)
RobertScheitlin__GISP
Krish,
   In that case you need this:
var hc = WidgetManager.getInstance().getWidgetsByName("HeaderController")[0];
hc.setOpenedIds([widgetCfg.id]);‍‍‍‍
Krish,
  Do you have the _getWidgetConfig function defined in your code?
_getWidgetConfig: function(widgetName){
  var widgetCnfg = null;
  array.some(WidgetManager.getInstance().appConfig.widgetPool.widgets, function(aWidget) {
    if(aWidget.name == widgetName) {
      widgetCnfg = aWidget;
      return true;
    return false;
  if(!widgetCnfg){
    /*Check OnScreen widgets if not found in widgetPool*/
    array.some(WidgetManager.getInstance().appConfig.widgetOnScreen.widgets, function(aWidget) {
        return true;
      return false;
  return widgetCnfg;
  if (widgetCfg) {
    editWidget = WidgetManager.getInstance().getWidgetByLabel(widgetCfg.label);
    if (editWidget) {
      WidgetManager.getInstance().openWidget(editWidget);
      PanelManager.getInstance().showPanel(editWidget);
    } else {
        editWidget = WidgetManager.getInstance().getWidgetById(widgetCfg.id);
      }, 3000);
KrishV
Hi Robert Scheitlin, GISP‌,
Yes, I have the _getWidgetConfig  function defined. I'm getting error at below line:
Error: Fail to startup panel widgets_Edit_Widget_59_panel. TypeError: Cannot set property 'done' of undefined
Regards,
Krish
Krish,
  If the edit widget part of the foldable themes header controller or is it just in one of the on screen placeholder positions?
KrishV
It is part of the Header controller.
above code is working if I open Edit widget after opening app and close it. But when I'm trying this without opening Edit Widget, it is giving error.
Krish
Krish,
KrishV
Yes! After setting below lines, Edit widget is getting opened.
Thank you so much!!
Krish
