Java Runtime Error on Ubuntu
1188
08-01-2018 03:38 AM
chenzero
I tried the Java Runtime on Ubuntu 16.04 and 18.04,
java runtime version: 100.3.0
Java version: jdk  8u181
and encountered following problem.
Please see the attched MyMapApp.java
on 18.04, the whole OS hang, no any response
on 16.04, can show the map.
If ran another sample code OpenScenePortalItemSample.java
Open Scene (Portal Item)—ArcGIS Runtime SDK for Java | ArcGIS for Developers
I only tested on 16.04 ,  exception thrown (attached in the err1.txt)
Perhaps that I should switch to windows platform?
Thanks!
chenzero
At last, we found that this is because of some issues with dual graphic cards with Ubuntu. after remove one, the code example worked as expected. Thanks !
