Coordinate System
2158
7
03-16-2018 06:16 PM
NickZubel
How do you use the “Project” tool to create a new layer in the same coordinate system as the other layers?
Thank you,
Nick Z
AbdullahAnter
Honored Contributor
Project  tool doesn't use for copy layers
you can copy layers using the following methods:
1. Right click on the layer on TOC and Export it.
2. Use Copy Features .tool.
3. use Feature Class To Feature Class tool.
NickZubel
Thank you. I will give that a try and let you know. Basically, I have three layers (census tract, census block and boundary) that are in different geographic coordinate systems and all of the layers must be in the same coordinate system in order use the Flood Information Tool in Hazus.
AbdullahAnter
Honored Contributor
sorry, maybe i don't understand your question well
so
the answer for your question is :
use Import while using Project tool and select the output coordinate system. and browse the other layer that you want to project to.
NickZubel
Am I trying to change the Projected Coordinate System or the Geographic Coordinate System?
Thank you,
Nick
NickZubel
Yes indeed. Thank you for the resources.
NickZubel
Thank you Abdullah Anter. I am unable to find the output coordinate system using the Import function in the Project Tool. But, I am able to search for it (WGS_1984_UTM_Zone_10N) in the Spatial Properties Box and select it.  The problem is I can't find the census tract, census block and boundary layers that I want to project to WGS_1984_UTM_Zone_10N because they are coming from an SQL Server. I believe that means they are accessing online data types? I may be mistaken.
