Problem with File geodatabase
4715
8
01-29-2011 01:58 AM
sujaygarapati
I am trying  to browse File geodatabase using common dialog box and open the feature dataset and then feature class in arcengine9.31 but unable to do it can any one help me
JohnHauck
What's happening when you try this? Please give some more details. Are you sure you've sucessfully checked out a license?
sujaygarapati
this is the code i wrote
  Private Sub OpenDialog_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OpenDialog.Click
        Dim openFileDialog As System.Windows.Forms.OpenFileDialog = New System.Windows.Forms.OpenFileDialog
        openFileDialog.InitialDirectory = "c:\"
        openFileDialog.Filter = "File GBD (*.GDB)|*.GDB"
        openFileDialog.FilterIndex = 2
        openFileDialog.RestoreDirectory = True
        openFileDialog.Multiselect = False
        If openFileDialog.ShowDialog = System.Windows.Forms.DialogResult.OK Then
NeilClemmons
Honored Contributor
A file geodatabase is a folder that contains many files that make up the database.  You can't browse to a folder using a file browser; you need to use a folder browser.  Or just use the standard IGxDialog used by the ArcGIS Desktop applications.
sujaygarapati
Thank you very much for  replaying,i  am trying  arcengine,i created a form which will will export shape file to feature class (FileGDB---->Dataset----->Featureclass),can you please provide any code
NeilClemmons
Honored Contributor
Use the search box at the top of the page.  There is also a link to the archived forums where you can also search.  There is also a sample for using the IGxDialog in the developer help.
sujaygarapati
AS IGXdialog interface belongs to destop ,so i cant use in arcengine
Venkata_RaoTammineni
http://hi.baidu.com/007day/blog/item/c6475eaf0dcd41fefaed5068.html
DebbieAlger
Hi Sujay,
Did you ever resolve this?? What a pain that ESRI removed this very important functionality in Engine.
