REST API rejecting just-generated token with "498 - Invalid Token"
3598
02-19-2018 11:27 AM
AryelTupinambá
Starting a few weeks ago, most requests to the REST API (specifically, the VRP API) are failing with the error "498 - Invalid Token".
From what I've gathered, error 498 implies an expired token, but the token used is a token that was generated immediately prior to the request.
The token is obtained by POSTing to https://www.arcgis.com/sharing/rest/oauth2/token/ , with grant_type set to client_credentials, passing client_id, client_secret and f=json. Then, the token is appended on a request to https://logistics.arcgis.com/arcgis/rest/services/World/VehicleRoutingProblem/GPServer/SolveVehicleR... , in the "token" field.
Has there been any changes to the way tokens are supposed to be generated/consumed?
JackSilburn
Hi Aryel
Did you ever manage to resolve this issue? I am facing a similar challenge, see my thread here:
https://community.esri.com/message/929157-re-arcgis-server-invalid-token-from-application-using-rest...
