Publish in ArcGIS Portal - Error Hosted Layer
1105
02-17-2018 10:31 PM
MayurDodiya
I have set the hosted server in portal for ArcGIS. Now, I am adding items from my computer e.g. zipped shapefile, I am getting the below error.
If I uncheck the check  box Published this file as hosted layer than it is uploading and showing in my content, but as hosted layer I am getting above error. Also, If I run Spatial Analysis widget in application I am getting the same above error.
I have configured the trusted SSL certificate for Portal.
Configuring the portal to trust certificates from your certifying authority—Portal for ArcGIS (10.6)...
All enterprise components installed (Portal, ArcGIS Server, Datastore) in single machine test server and configured porperly.
So kindly suggest us how to resolve this issue.
JonathanQuinn
Esri Notable Contributor
Your Portal doesn't trust the certificate used for the admin URL of the hosting Server. Are you using the machine URL, (ex https://server.domain.com:6443/arcgis)? Did you import your own certificate to use for Server's web server?
