Multi-line text fields not showing up on Survey123 print
1709
01-26-2018 01:54 PM
AndrewSouthern
I am trying to print individual Survey123 responses and noticed that the multi-line text fields from my survey are not available for print.  Has anyone else experienced this?
I have a survey built for the fire department to be used during inspections and have a handful of multi-line text fields to be used to describe potential violations.  I have also had trouble creating report templates, I get a general error that the report did not generate properly, and I'm assuming it's due to the multi-line text fields as well but am not 100% certain.
The fields could possibly be changed to single line text fields which appear as expected but wanted to know if this is an expected behavior or not.
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
We have identified a fix for this issue and are in the process of certifying before updating the Survey123 website.
AndrewSouthern
Great thanks for the quick reply.
