group widgets in folder in Ldockable Panel
1852
12-13-2017 03:08 AM
aishvaryvardhan
I am using jewelry box theme, i want to group widgets in Ldockable panel. I am able to group them by increasing the max-widget in config.json. but they are not displaying in frontend. Only the first one is coming.
is there any way i can achieve it ?
please find  snapshot
Any help on this is highly appreciated.
Ash
Tags (1)
RobertScheitlin__GISP
Ash,
   The LDockablePanel has to be extended to support this. The reason that the maxWidget is not a UI configurable option is that there is no sizing code to support adding more than one widget in the panel.
Here is an update to the Panel.js to add that basic support:
// Copyright © 2014 - 2017 Esri. All Rights Reserved.
// Licensed under the Apache License Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//    http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
define(['dojo/_base/declare',
    'dojo/_base/lang',
    'dojo/_base/html',
    'require',
    'dojo/topic',
    'dijit/_TemplatedMixin',
    'dojo/text!./Panel.html',
    'jimu/BaseWidgetPanel',
    'jimu/dijit/LoadingIndicator',
    'jimu/utils',
    'jimu/BaseWidgetFrame',
    'dojo/_base/array'
  function(
    declare, lang, html, require, topic,
    _TemplatedMixin, template, BaseWidgetPanel, LoadingIndicator, utils,
    BaseWidgetFrame, array
    //jshint unused:false
    This panel is dockable at left
    return declare([BaseWidgetPanel, _TemplatedMixin], {
      baseClass: 'jimu-panel jimu-ldockable-panel',
      templateString: template,
      width: 0,
      postCreate: function(){
        this.inherited(arguments);
        this.maxWidth = this.position.width;
      startup: function(){
        var configs = this.getAllWidgetConfigs();
        if(Array.isArray(this.config.widgets)){
          configs = this.config.widgets;
        }else{
          configs = [this.config];
        if(configs.length > 0){
          html.empty(this.containerNode);
      loadAllWidgetsInOrder: function(){
        console.info(this.config.maxWidgets);
        }else{
        array.forEach(configs, function(widgetConfig){
          var frame, loading;
          if(widgetConfig.visible === false){
            return;
          loading = new LoadingIndicator();
          frame = this.createFrame(widgetConfig);
          frame.containerNode.style.height = (100 / parseInt(this.config.maxWidgets)) + "%";
          this.addChild(frame);
          frame.setLoading(loading);
          this.widgetManager.loadWidget(widgetConfig).then(lang.hitch(this, function(widget){
            frame.setWidget(widget);
            widget.startup();
        }, this);
      createFrame: function(widgetSetting){
        /*jshint unused: false*/
        return new BaseWidgetFrame();
      onOpen: function(){
        this._setPostionWidthAndLeft();
        html.setStyle(this.domNode, {
          width: this.position.width + 'px'
        if(this.position.width === 0){
          this.panelManager.minimizePanel(this);
        }else{
          this.panelManager.maximizePanel(this);
      setPosition: function(position){
        topic.publish('changeMapPosition', {left: this.position.left + this.position.width});
      onMaximize: function() {
        html.addClass(this.barNode, 'max');
        html.removeClass(this.barNode, 'min');
        this.position.left = 0;
        this.setPosition(this.position);
      onMinimize: function() {
        html.removeClass(this.barNode, 'max');
        html.addClass(this.barNode, 'min');
        //on minimize, we can't set width/height = 0 to minimize because we use border-box model
        //and the content height/width can't be nagative
        //go here for more information: http://dev.w3.org/csswg/css-ui/#box-sizing
        this.position.left = 0 - this.position.width;
      resize: function(){
        var style = utils.getPositionStyle(this.position);
        style.position = 'absolute';
        html.setStyle(this.domNode, style);
      _setPostionWidthAndLeft: function(){
        if(window.appInfo.isRunInMobile){
          var box = html.getMarginBox(window.jimuConfig.layoutId);
          this.position.width = box.w * 0.8;
          if(this.position.width > this.maxWidth){
            this.position.width = this.maxWidth;
        }else{
          this.position.width = this.position.width;
        // if(this.windowState === 'minimized'){
        //   this.position.left = 0 - this.position.width;
        // }else{
        //   this.position.left = 0;
      _onBarClick: function() {
        if (this.windowState === 'maximized') {
        } else {
Ash,
    'dojo/_base/lang',
    'dojo/_base/html',
    'require',
    'dojo/topic',
    'jimu/utils',
    'dojo/_base/array'
  function(
      width: 0,
        }else{
        }else{
          var frame, loading;
            return;
            widget.startup();
        }, this);
      onOpen: function(){
        }else{
      resize: function(){
        }else{
        // }else{
        } else {
aishvaryvardhan
Seems great, will check with my app
Thanks a lot Robert
Great don't forget to mark this as answered as soon as you test and see that it is.
