How can I restrict access to the attribute table via pop-up
1265
12-06-2017 02:39 AM
D_Visca
is it possible to deactivate the possibility to show the attribute table via pop-up in web maps? I have some sensitive data in it (which are necessary to keep there) and I want the standard user only to see the information I put into the pop-up.
Regards,
Dominik
KellyGerrow
Esri Alum
Hey Dominik,
I'd suggest creating a view layer  for your app that doesn't include the fields that you want to hide. Users who access the layer will only be able to see the fields that you make available through the view definition, while the fields can be maintained and used through the original layer or another view.
Check out this documentation for more details on view layers:
Whats new with hosted feature layer views | ArcGIS Blog
Create hosted feature layer views—ArcGIS Online Help | ArcGIS
-Kelly
RobertScheitlin__GISP
Dominik,
   Are you talking about removing the "View in Attribute Table" Action menu option from the popup in WAB?
