Disable Map Panning for an event
1964
10-24-2017 10:22 AM
NicholasLiccini
Hi!
I would like to have the ability to control whether you can pan the map from the map view based on certain signals. How would I be able to toggle whether the user can pan the map using the same settings that ArcGIS provides?
Thanks!
Nick
LucasDanzinger
Esri Frequent Contributor
You will need to "accept" the mouse signals so they don't go through, and that should stop the default behavior from happening
connect(m_mapView, &MapGraphicsView::mousePressed, this, [this](QMouseEvent& event)
  event.accept();
LucasDanzinger
  event.accept();
NicholasLiccini
This worked! Thank you
