Arc Pro Copy past attribute table into excel
29463
11
10-18-2017 03:44 PM
AnuSawant
I was trying to copy past attribute from table to excel, it seems this option is not available in arc pro......right?
EvanMosher
In ArcGIS Pro, use CTRL+SHIFT+C  to copy selected records in attribute table, this allows to then paste in excel.
Shortcut keys for working with tables—ArcGIS Pro | ArcGIS Desktop
DanPatterson_Retired
Pro isn't the same the same as map... the common thread is
http://pro.arcgis.com/en/pro-app/tool-reference/conversion/table-to-excel.htm
short cuts may exist, but the standard workflow is to use tools.
AnuSawant
Hi Dan,
Thanks for the reply. I know about this tool but it is sometimes easy to just do copy paste instead of following many steps. I have found another tool on ribbon  which is "Export Table" , but again it is same workflow to follow couple of steps
Anu
That's the problem with shortcuts, the standard methods get forgotten or ignored first.
EvanMosher
Nice find! bookmarked
AnuSawant
Thanks Evan....shortcuts are always helpful when you want to do quick work.
LinasNera
Į wonder why millennium-aged steps now have been changed?
evolution
KoryKramer
Esri Esteemed Contributor
New command in the attribute table will be coming to Pro 2.2 which will help with this workflow:
