Calculate repeating values in field
6272
12
10-13-2017 03:48 PM
JeffBaker2
Anyone have any ideas how to calculate a field so the values (going down the table) are
etc. to the end of the table?
These values will end up being color codes for rendering.  The actual values will be from 0-9, but need some way to get the repeating values in.  Another option might be to calculate random values instead of repeating values.  Any thoughts?
DarrenWiens2
This passes the current field value to the function (not what you want - would pass all 0s first time, then all 1s, etc.):
seq_num_max(!ColorCode!)‍
Try (you always want 3):
seq_num_max(3)‍‍
And code block (untested):
cnt = 0
def seq_num_max(val):
    global cnt
    if cnt < val:
        cnt += 1
    else:
        cnt = 0
    return cnt
Or (untested):
cnt = -1
  global cnt
  cnt += 1
  return (cnt % val) + 1
DanPatterson_Retired
cnt = 0
    global cnt
    if cnt < val:
        cnt += 1
    else:
        cnt = 0
    return cnt
# in expression box ... seq_num_max(3) ... will number from 0 to 3 before repeating
will get you started ... for use in the field calculator obviously
MicahBabinski
I think this would do it:
In field calculator Codeblock (Python):
def Calculate(repeatingValue):
    interval = 1
    if cntr < 3:
        cntr += interval
    else:
        cntr = 1
    return cntr‍‍‍‍‍‍‍‍‍
Then in your expression it would be Calculate(!YourFieldName!)
Micah
DarrenWiens2
for i in range(10):
    print (i % 3) + 1
JeffBaker2
Thanks for your replies.  Dan, Micah, each of your code pieces seems to run well, but the values are not populating in the highlighted field.  All rows remain Null--see below.  Ideas?
MicahBabinski
Hey Jeff,
You'll need to apply that function in the main calc expression box:
That should do it.
JeffBaker2
I am now getting all zero's in the ColorCode field.  Am I setting up the Field Calculator dialog correctly?  Or maybe something else?
JeffBaker2
A little more info now . . .
Each time I run this code:
cnt = 0
    global cnt
    if cnt < val:
        cnt += 1
    else:
        cnt = 0
    return cnt
The result calculates ALL values to 0, then to 1, then to 2, then 3, then back to 0 again, and so on.  Still not sure how to get the repeating values?
DarrenWiens2
seq_num_max(3)‍‍
cnt = 0
    global cnt
    if cnt < val:
        cnt += 1
    else:
        cnt = 0
    return cnt
Or (untested):
cnt = -1
  global cnt
  cnt += 1
JeffBaker2
And Darren hits the grand slam . . . that worked!  Thank you!
You gave two suggestions--the second one did the trick.
Thanks to all who shared your ideas.
