Disable mouse double click zoom
3649
6
10-04-2017 09:20 AM
BikeshMaharjan1
I wanted to remove mouse double click zoom but retain the scroll wheel zoom. Is it possible?
dotMorten_esri
Esri Notable Contributor
WPF or UWP?
BikeshMaharjan1
WPF
dotMorten_esri
You just handle the doubleclick preview-event, which prevents the mapview from receiving the double-click:
myMapView.PreviewMouseDoubleClick += (s, e) => e.Handled = true;
BikeshMaharjan1
I want to use MyMapView_GeoViewDoubleTapped though. Is there any other way?
AndyWright
Hi Morten.  How would I accomplish this in Xamarin?  There is no PreviewMouseDoubleClick event to work with there.  And just setting handled = true in the GeoViewDoubleTapped event does not do the trick.
dotMorten_esri
The double tapped event is too late. I believe if you handle it in the GeoViewTapped event, the doubletapped won't fire.
Alternatively, you can use the MapView.InteractionOptions to disable zoom.
