Labelling woes... (in Pro or in ArcMap)
27806
48
08-30-2017 07:04 AM
AdrianWelsh
MVP Honored Contributor
I am not sure there is an "easy" answer to this but I have given up and am relying on GeoNet to pull me out of a jam.
Is there an "easy button" for labelling just the way I want it? Here are about 66 polygons that need labels visible for each one and need to see the polygon. In Pro, this is how they look without much change in the properties:
I want to see all the labels so I choose Never remove. This is what I get:
Even if I throw in a 50 point offset, 200 point max overrun, 50% buffer, 100 point feature weight to interior and boundary features (and other tweaks), this is my result:
Is there some sort of magic button that will not allow labels to overlap each other? I have attempted to mess around with all of the settings in the label properties and have not come up with a good solution (I do have Maplex Label Engine turned on). My best bet is to convert to annotations and move them that way, manually, by hand, one at a time. (small snippet: )
I keep thinking I'm missing something super obvious. Tell me where I can find the easy button (in ArcGIS Pro preferably or ArcMap - it doesn't matter). Thanks!
JayantaPoddar
How about using Maplex, and Key Numbering as a Fitting Strategy?
About key numbering—Help | ArcGIS for Desktop
Think Location
AdrianWelsh
I had never really used key numbering. I tried it but didn't get the best outcome, unfortunately. Here is a sloppy screenshot
you can see numbers 1 and 2 but other things are thrown around like before.  (the number code is at the top, not shown). Here's another look at a different scale:
So, I'm guessing key numbering isn't really going to give me the magic answer. Thanks for the suggestion!
JayantaPoddar
What are the other fitting strategies you are using?
Keeping the Key Numbering checked, let me know what happens if you
1. Uncheck Place Overlapping Features under Conflict Detection.
2. Use Halo Mask for Labels instead of the Text Box.
Think Location
AdrianWelsh
So I learned that in order to uncheck Place Overlapping Labels in Pro, you have to turn OFF Maplex Label engine:
Place overlapping labels—ArcGIS Pro | ArcGIS Desktop
Turning this off results in losing many of the other benefits that maplex brings. Here is the result after step 1:
And here is the result after using halos instead of call out boxes:
It looks like there is no magic button for this predicament and have to go with converting to annotations... Thanks for your help!
WendyHarrison
Hi Adrian,
You don't need to turn off Maplex to turn off the option.  it is called Never remove (place overlapping)
AdrianWelsh
Wendy,
I appreciate the note about leaving Maplex on. When I wrote this thread, almost a year and a half ago, I am not sure what version of Pro I was on. Maybe 1.4? From what I recall, that option was not around. I am happy to see it is around now. Or it is very possible that I just missed it altogether.
by Anonymous User
Not applicable
The never remove results in the cluster :::: mess that the original post related to.
JustinConnerWR
It would be helpful if key numbering could be enforced for all labels for a given label class.
MartynTattersall
Hi Alison,
You can force all labels to key numbering by setting an extreme offset that lays outside the map extents. The ruling applies if a label cannot be placed normally and because it is outside of the map extents it will be given a key number instead.
Hope this helps and isn't too late.
Martyn
