How to load separate Configs from a URL parameter for WAB Dev Edition
3421
08-02-2017 12:02 PM
BrendanCunningham1
Back in the glory days of the Flex viewer it was possible to load a URL parameter for separate configs from a URL, eg:
index.html?config=rivers.xml
index.html?config=roads.xml
etc
Is it possible to load separate config.json files through a URL parameter as a similar approach for WAB Developer Edition? Or can this be embedded in the basic index.html as a similar method?
I have about 10 applications where the config is largely the same but some widget configs are not identical. So this approach would allow me to use a simple parameter to link to different configs and ultimately different widget settings.
Thanks a lot,
Brendan
RobertScheitlin__GISP
Brendan,
   Absolutely you can it is not documented very well but they show this ability in the WAB guide.
Get started—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
http://<server[:port]/webappbuilder/stempapp/?config=sample-configs/config-demo.json
Brendan,
BrendanCunningham1
Hi Rob,
Thanks for that - indeed I searched long and hard for this! It surely is buried.
Much appreciated,
Brendan
