Related tables not appearing in WAB app using MS Edge and IE11
2779
5
07-17-2017 11:18 AM
BarnabyRockwell
I have a public (https) app made using WAB Dev 2.4 and the LocalLayer widget.  One layer in it is a nationwide vector geodatabase (tiled) that includes related tables.  Using Firefox x64 and Chrome x64, the related tables reliably appear in both the Attribute Table widget and in pop-ups for that layer.  However, the tables seldom, if ever, appear when the app is used in MS Edge or IE11.  I also can't see the tables when the app is viewed using Safari browser in iOS 10.3.3 (on a iPhone).
On rare occasions, the tables will appear in the Attribute Table widget in Edge and IE11, but never in the pop-up for the vector layer.
I have various similar internal apps for which the tables do appear in IE11and Edge, but those apps are on http servers.  I have another internal, http WAB Dev app which calls an AGOL web map, and the tables in that one also appear in all browsers.
Has anyone else had a similar issue?  Does anyone know how I can get the tables to appear reliably in all browsers?  Since the issue is intermittent, it points to some WAB instability with regard to MS browsers.
Thanks in advance....
BarnabyRockwell
Issue has been fixed by new 2.5 beta version of LocalLayer widget.
AhjungKim4
If it is a public app, can you share the link?
BarnabyRockwell
ArcGIS Web Application
AhjungKim4
for the sake of narrowing things down, if I have node.js running in the background, IE displays the related tables.  IE consistently hides related tables when I kill the node.js.  I'll post when I learn more.
BarnabyRockwell
Great info!  Thank you very much for looking into the issue!  🙂
Let me know if I can provide you with more data/info.
BarnabyRockwell
