Criteria / Calculation Based Select_One Auto-Population
2474
07-11-2017 12:22 PM
ChrisSmith2
Survey screenshot
In the attached screenshot the main question is "All Other Signs (Guide Signs & Delineators)"
The highlighted sections above are fields to calculate fail % so the person taking the survey doesn't have to take any extra notes or do any calculations on the side.
If possible, what I would like to have happen is:
If both totals fall under their % limit - Pass is automatically selected.
If one or both are above the % limit- Fail is automatically selected.
If total # of signs = 0 in both fields - N/A is automatically selected.
Is it possible to have a Select_One question auto-populate based on previous answers or selected criteria?
JohnathanHasthorpe
Hi Chris - unfortunately it is not possible to use calculations to update select_one questions (in your case we would want to update the select_one using the answer to a previous question). I will get you added to the enhancement request we have open for this functionality.
OlivierCottray1
hello
any update on this issue by any chance? i'm comping up against exactly the same requirement.
thanks for any advice.
by Anonymous User
Not applicable
Hi Olivier,
Yes, calculations will be supported on select_one questions as of version 2.7, which will be released in the next few weeks.
Phil.
OlivierCottray1
Hi Phil
That’s great news; thanks-
Olivier
