Java Dockablewindow Disabled JTextField.
5369
6
01-10-2011 03:19 PM
ShaunMartin
I have created a add-in for Arcmap that contains a DockableWindow with a panel and a JButton and JTextfield. When I load the DockableWindow my button and textfield are visible and the button behaves as correctly and can be clicked .The textfield is un-useable it will not allow adding text etc. I have ensured that it is editable via the code and I have even tried to force the focus via the code but I'm still unable to use it. I have also tried using a JTextArea with the same result.
Here is a sample of the code from the dockablewindow createUI method
@Override
  public Component createUI() {
   panel = new JPanel();
      keywordTF = new JTextField(10);
      keywordTF.setText("something");
      panel.setLayout(new BorderLayout());
      panel.add(keywordTF,BorderLayout.NORTH);
      return panel;
Any help with this would be great.
Thanks Shaun
KeithCroteau
Hi Shaun - I logged and incident with ESRI and they have just confirmed that
this is a bug.  I will post again if ESRI contacts me with a fix, or if I find a workaround.
Thanks, Keith
Excerpt from Esri:
Here is the defect which is logged for this issue:
NIM060914: "Dockable Window does not recognize JTextField.setEditable(true) text field for a Java".
KeithCroteau
Hi Shaun - did you have any luck resolving this?  I am having the same problem.
Thanks.
@Override
      return panel;
Thanks Shaun
ShaunMartin
Hi Keith,
No unfortunately I haven't been able to resolve this problem. You would think that ESRI would monitor these forums and give some solution to issues such as this.
Cheers,
Shaun
KeithCroteau
Thanks, Keith
Excerpt from Esri:
TomSchuller
Hy,
I'm also blocked by this bug.
Has anybody a workaround or an information for the fix?
Tom
ShaunMartin
Hi Tom,
The only work around I could think of was to put an edit button that pops a JOptionPane get the input and push it into the disabled edit box. Ugly I know but its the only way I could think of.
Cheers,
Shaun
GregSpiridonov
As far as I can tell it is still an issue in the 10.4 prerelease Java API.
