A feature overlapped with another feature
3654
9
06-29-2017 10:25 AM
ShaningYu
Honored Contributor
In my ArcObjects program, I need to check where a polygon feature (named f_A here) is included / overlapped with another polygon feature (named f_B hear).  Is there an ArcObjects method for the this check-up?  Thanks.
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
MicahBabinski
Hi Shaning,
This would be really easy with arcpy, but from what I can tell this article might help you out with how to use the Intersect tool with ArcObjects geoprocessing:
https://www.esri.com/news/arcuser/1207/files/gp_arcobjects.pdf
Or, the ITopologicalOperator.Intersect method could be used to determine if there is overlap.
Good luck!
Micah
KenBuja
Here's how I determine if a polygon overlaps another polygon
pTopoOp = pFeature.Shape
Dim pInGeometry As ESRI.ArcGIS.Geometry.IGeometry5
pInGeometry = pOtherFeature.Shape
If pInGeometry.Dimension = ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry2Dimension Then 'check if the feature is a polygon
  pOverlapGeometry = pTopoOp.Intersect(pInGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry2Dimension)
  If Not pOverlapGeometry Is Nothing And Not pOverlapGeometry.IsEmpty Then
    'you've got an overlapping polygon
  End If
End If
ShaningYu
Honored Contributor
Ken:  Thanks for your code.  Could you tell me what is the data type of  pOverlapGeometry  since I need to convert your VB into c#.  Thanks.
KenBuja
It's an IGeometry5 object
ShaningYu
Honored Contributor
Before I sent my last message to you, I did try but got error:
'ESRI.ArcGIS.Geometry.IGeometry5' does not contain a definition for 'Intersect' and no extension method 'Intersect' accepting a first argument of type 'ESRI.ArcGIS.Geometry.IGeometry5' could be found (are you missing a using directive or an assembly reference?) .
My code is below:
        bool feature_In_Other(IFeature f1, IFeature f2)   {
            IGeometry g = (IGeometry)f1.ShapeCopy;  // also tried   IGeometry5 g = (IGeometry5)f1.ShapeCopy;
            ESRI.ArcGIS.Geometry.IGeometry5 pInGeometry = (ESRI.ArcGIS.Geometry.IGeometry5)f2.ShapeCopy;
            if (pInGeometry.Dimension == ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry2Dimension)      {
                if (f1.ShapeCopy.GeometryType == esriGeometryType.esriGeometryPolygon)         {
                    ESRI.ArcGIS.Geometry.IGeometry5 pOverlapGeometry = g.Intersect(pInGeometry, ESRI.ArcGIS.Geometry.esriGeometryDimension.esriGeometry2Dimension);  // Got error on this line
What's wrong in my code?  Thanks.
KenBuja
The Intersect method is called on the ITopologyOperator object. In my code, that's what the pTopoOp is.
Dim pTopoOp As ESRI.ArcGIS.Geometry.ITopologicalOperator
ShaningYu
Honored Contributor
Ken:  I revised the code per your feedback. The error was gone.  Thanks.
JoshuaBixby
How to Execute Spatial Queries—ArcObjects 10.4 Help for Java | ArcGIS for Desktop .  The article is for Java, but the concepts translate to .NET.
ShaningYu
Honored Contributor
Thanks a lot.
