Joining a hosted feature class with a survey123 form
1570
06-21-2017 10:40 AM
MikeOnzay
Is it possible to join a hosted feature class with a survey123 form feature service for display in a ArcGIS Online map? I essentially want to create a relate or relationship class like in ArcGIS desktop. I've seen the join command under the analysis tab. Is what I described the purpose of this join command?
If not, how would I go about to achieve this type of join?
by Anonymous User
Not applicable
Hi Mike,
I do not believe it is currently possible to create a join or relate between two feature services/classes in the way you are describing.
This is more of a ArcGIS Online question versus a specific Survey123 question, as the feature service created by Survey123 is the same as any other hosted feature service created a different way.
More information on joins and relates in ArcGIS Online can be found here: FAQ: Does ArcGIS Online support joins and relates?
Regards,
Phil.
