Arcpy Layer class minScale
3309
7
04-28-2017 01:32 PM
DevinUnderwood2
What is the syntax to retrieve all layers' set minimum scale ?
DevinUnderwood2
for layer in layers:
                    if layer.isFeatureLayer:
                        lyr_source = layer.dataSource
                        lyr_name = layer.name.encode("utf8", "replace")
                        print fullpath + " " + lyr_source + " " + str(layer.minScale)
                        scale = [layer.minScale]
                        # Write to Excel
                        b = fullpath.split('\\') + lyr_source.split('\\') + scale
                        writer.writerow(b)
Thanks, everyone I arrived at my final solution.
DanPatterson_Retired
not sure what you mean beyond it returning a double (number).  Are you wanting to cycle through all the layers and return the minScale for each?  Did you try something and it didn't work?
DevinUnderwood2
I haven't tried anything yet and yes you are correct as I did not have any luck searching the internet to achieve this.
The arcpy help is your best bet... this is the layer section
and from there, nothing too exciting ... maybe...  mylayer.minScale if it is property
minScale
(Read and Write)
Provides the ability to set or get the layer's minimum scale threshold.
Double
As for arcpy.... bookmark the start of its menu tree... Arcpy ... , Dr Google isn't very good at tracking down all the properties and methods
DevinUnderwood2
I know that it can be done, documentation is lacking.
RandyBurton
Try:
mxd = arcpy.mapping.MapDocument("CURRENT")
for lyr in arcpy.mapping.ListLayers(mxd):
    # to read minScale
    print lyr.minScale
    # to set minScale
    lyr.minScale = 500.0
DevinUnderwood2
Perfect, I arrived at the same.
Make sense, set the mxd and loop layers.
I will add this to an existing script that write data to csv.
DevinUnderwood2
                        # Write to Excel
                        writer.writerow(b)
