Calculating counting field
3745
5
03-07-2017 10:02 PM
KelvinMwakomo
Hello guys,
Assistance please,
I have a table below;
From there i created a new field "code" so i want to calculate a sequential numbers based on how much the "Unique_no" appears like the one below;
Regards,
Kelvin.
NeilAyres
You could do this with an update cursor and a dictionary, something like this...
data_dict = {}
with arcpy.da.UpdateCursor(fcName, ["Unique_no", "Code"]) as Cur:
    for row in Cur:
        if row[0] in data_dict:
            # increment counter
            data_dict[row[0]] += 1
        else:
            data_dict[row[0]] = 1
        # update code
        cnt = dat_dict[row[0]]
        row[1] = cnt
        Cur.updateRow(row)
NeilAyres
data_dict = {}
    for row in Cur:
            # increment counter
        else:
        # update code
        row[1] = cnt
        Cur.updateRow(row)
KelvinMwakomo
Thanks Neil,
See if I'm wrong somewhere because i am not good in python.
NeilAyres
Firstly try and run this as a script in IDLE or pyscripter or something.
You have the indentation wrong. The line starting else:
Should be at the same level as the if:
Indentation in python is a crucial part of the language syntax.
Try doing a bit of reading up on python first.
NeilAyres
And the last 3 lines also at the same indentation level as the if:
JoshuaBixby
MVP Esteemed Contributor
Using defaultdict allows the code to be simplified/condense a bit:
from collections import defaultdict
data_dict = defaultdict(int)
with arcpy.da.UpdateCursor(fcName, ["Unique_no", "Code"]) as cur:
    for uniq, code in cur:
        data_dict[uniq] += 1
        cur.updateRow([uniq, data_dict[uniq]])‍‍‍‍‍‍
