Show loading message while the widget is doing operations
5358
7
10-06-2016 05:18 AM
MargaRaiz
Hi!
I need to show a loading icon or something similar while the widget is performing a query or other operation. I have never done this before (no in JS or WAB) and I am quite lost. I would like something simple, just to make understand to the user that he/she needs to wait.
Any idea or tip for having something to start work on please?
Thanks!
Marga
RobertScheitlin__GISP
Marga,
  Sure use the WAB dijit designed for that purpose:
Widget.js:
Require
'jimu/dijit/LoadingShelter',
methods
this.shelter.show();
this.shelter.hide();
Widget.html:
<div>
  <div>my widgets content</div>
  <div data-dojo-type="jimu/dijit/LoadingShelter" data-dojo-attach-point="shelter" data-dojo-props="hidden:true" style="overflow:hidden;"></div>
</div>
Marga,
Widget.js:
Require
methods
Widget.html:
<div>
</div>
MargaRaiz
Hi Robert! I will try and keep you informed.
thanks!
Itziar
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
MargaRaiz
Of course! I was just waiting to check it if it works and it works, thanks!
JohnLocke1
Hi Marga!
I would like to use this in my widget, but I'm so beginner in this. Can you help me? I understand, what should I do with the html, but it's not clear, where should I write these lines into the widget.js. Can you printscreen it?
Thanks, John
John,
   Just add the
to your widget.js define array.
Then in your code startup or open method call
and when your widget is done tasks that take some time call
JohnLocke1
Thanks Robert, you're awesome as usual
