Mapping non-group fields into Group fields using Field mapper
1752
09-30-2016 03:55 AM
AhsanMukhtar1
I have received json as input on a tcp socket, and created a GeoEvent service that sends it into  json file in output folder. The input json has no group field but i want to send output having a group field. I tried to bind it using Field Mapper but it did not work. I have created a separate definition having group field that i want as output. How can i convert my non-group json input to group output json.
Input JSON :
   "id" : "R1",
   "lat" : 73.0001,
   "long" : 33.0014
Output JSON:
      "data" : {
        "id" : "R1",
         "lat" : 73.0001,
         "long" : 33.0014
RomanChueh
Have you find a solution to your problem?
deleted-user-GKyg-xriCvci
I know it is an old question bus has anyone found an answer? Or is there some kind of workaround of how to send output JSON which has grouped attributes?
