Problem with import in HEC-GeoRAS / RAS - Floodplain Mapping
4556
09-28-2016 08:39 AM
Lucasde_Souza
Good evening.
I am writing this message because I was doing the mapping of a flood plain, for my research, and I found a problem.
I did all the steps of a tutorial on youtube:
https://www.youtube.com/watch?v=kM2XWb5dNoQ
https://www.youtube.com/watch?v=36wdta8JGbU
https://www.youtube.com/watch?v=aziti65d21E
Which match with HEC-RAS manual.
I performed all the steps in Arc-GIS and GIS I exported successfully Format.
But when importing GIS Format in HEC-RAS, the design does not appear as it should.
Below post the image ArcGIS (as it should appear in the HEC-RAS), and the image that appeared when I opened the file in HEC-RAS.
If anyone has an idea of why this is happening, I will be very grateful.
Imagem ArcGIS http://oi67.tinypic.com/nvxhj9.jpg
Image HEC-RAS http://oi68.tinypic.com/f1jk07.jpg
SaskiaEderle
I think I have the same problem. I did a tutorial for HEC-GeoRAS and my imported file in HEC-RAS looks similar to the one you added. I got no error messages and have no idea what I could have possibly done wrong.
Did you find a solution for your problem or is there anyone else that can help?
Best, Saskia
SaskiaEderle
Hello again,
I found the solution (at least for my problem). The created .sdf-file used a comma as decimal separator for the coordinates (probably from my operating system). So I changed those to a "point" with a text editor. Now HEC-RAS imports the file correctly.
