WAB Error on startup in init.js
4145
5
08-24-2016 01:01 PM
LeonS
I have an app I developed with WAB 2.1 developer edition.  When the app starts up it throws a couple of errors (found using Firebug).
Anyone run into this or something similar?
Leon
Tags (1)
RobertScheitlin__GISP
Leon,
   The first error I have not seen on my end . But the second is likely because you do not have the woff mime type added to your web server.
Set mime types for web fonts in IIS » Coding Still
Leon,
LeonS
Thanks, Robert.
Your suggestion for adding the mime type to the web server fixed that particular issue.  Still working on the first.
Leon
LeonS
First error resolved -
It seems I had an item in my AGOL account as part of one my basemaps that was not shared publicly.  The AGOL item is just a reference to a service hosted on my ArcGIS server, so the data actually showed up in the map.
LeoLadefian5
I'm getting a similar error, int.js.182, you do not have permission to access this resource, it's kinda driving me crazy since I think everything is shared publicly.
LeonS
I had some help from Esri support to find the issue.  I was able to see the service that was causing the error using the Network tab under the Chrome Developer Tools.  Firefox has a similar set of tools, if you prefer that browser.
