Web AppBuilder config url parameter
4212
08-12-2016 02:39 AM
FlavieMORAUX1
With webapp builder it is possible to transmit json config file name throught URL parameter "config".
.../index.html?config=config_specific.json.
But it is not documented : Use URL parameters—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Is it normal? This URL parameter is it doomed to disapear?
Flavie
RobertScheitlin__GISP
Flavie,
  You are correct it is not documented in the URL parameters help page but it is used and in other help docs:
Create a custom in-panel widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developer...
To preview the final result of the custom widget, type http://[your host]/webappviewer/?config=sample-configs/config-demo.json in the browser. When the app starts, click the first icon highlighted in red circle as shown below.
I will tag Jianxia Song on this.
Flavie,
Jianxia
We will document it in the coming 2.2 release. Thanks!
