Can you add tabs to pop-up in web appbuilder developer
6269
9
08-08-2016 02:55 PM
AronHarris
Does anyone know what file has the pop-up info window in Web AppBuilder to change it to tabs. To display the information of each layer on the tabs.
deleted-user-CQZbjNeBXm49
Hi Aron,
I have you taken a look at @Larry's Custom Widgets (Anvil), see links below including preview:
Larrys Custom WAB Widgets and More
ArcGIS Web Application (Preview Link)
Baba
AronHarris
Hi Baba,
Thanks for the link. Have you used this one?
I want to get  rid of the arrow that display the other layer information and have it show in the tabs.
Hi Aron,
See the link as posted by Rod Woodford
Baba
EricHeinrichs
It looks like this has been discontinued, and I can't download this. Is there any other way to add this functionality into WAB?
Hi Eric,
I don't know the policy here but if you need to download it maybe rastrauch‌ or rscheitlin‌ can help you, however I do have the zip file
Baba
CodyBarrett1
Hi Baba, may you provide that zip file?
Hi Cody,
Am sorry I don't have the permission to do that as I am not the "Right Holder" to the file, only Larryhttps://community.esri.com/message/631755-re-larrys-custom-wab-widgets-and-more?commentID=631755?sr=...‌ has got that and unfortunately he hasn't been active on here.
Baba
RebeccaStrauch__GISP
Some of Larry's widgets were uploaded #WebAppBuilder for #ArcGIS - Custom widgets directory by Larry I believe.  I have a note about it on the /blogs/myAlaskaGIS/2016/03/09/web-appbuilder-developer-edition-customization-resource-list?sr=search...‌  but as mentioned, Larry switched jobs and therefore is not currently supporting any of the widgets he wrote.
RodWoodfordOld
Hi Aron,
I asked a similar question re the eSearch widget having this type of functionality. See post below.
eSearch - Multiple result set configuration option
cheers
