modify event to task from wpf sdk to .net sdk
1724
08-05-2016 06:43 AM
vineetdubey
can you give me example for modify event to task from wpf sdk to .net sdk.events are like GraphicMouseButtonEventArgs,GraphicMouseEventArgs,ExtentEventArgs,LengthsEventArgs,DrawEventArgs,TaskFailedEventArgs that are define in wpf using client dll but in .NET sdk we not found any class so we got a error
MichaelBranscomb
Esri Frequent Contributor
ArcGIS Runtime SDK for .NET uses a combination of both events and asynchronous tasks depending on the context. Can you provide some specific examples (with code) where you are having difficulty transitioning to the new API?
Cheers
Mike
vineetdubey
Imports System.Windows
Imports System.Windows.Controls
Imports System.Windows.Input
Imports ESRI.ArcGIS.Client
Imports ESRI.ArcGIS.Client.Geometry
Imports System.ComponentModel
Namespace ArcGISWPFSDK
   Partial Public Class LocalToolkitFeatureDataGrid
   Inherits UserControl
   Implements INotifyPropertyChanged
   Public Event PropertyChanged As PropertyChangedEventHandler Implements INotifyPropertyChanged.PropertyChanged
   Private _isBusy As Boolean = True
   Public Property IsBusy() As Boolean
   Get
   Return _isBusy
   End Get
   Set(value As Boolean)
  _isBusy = value
   RaiseEvent PropertyChanged(Me, New PropertyChangedEventArgs("IsBusy"))
   End Set
   End Property
   Private _lastGraphic As Graphic
   Public Sub New()
  InitializeComponent()
   AddHandler MyMap.Layers.LayersInitialized, AddressOf map_LayersInitialized
   End Sub
   Private Sub map_LayersInitialized(sender As Object, e As EventArgs)
  DataContext = Me
  IsBusy = False
   End Sub
   Private Sub FeatureLayer_MouseLeftButtonUp(sender As Object, e As GraphicMouseButtonEventArgs)
   If _lastGraphic IsNot Nothing Then
  _lastGraphic.UnSelect()
   End If
  e.Graphic.[Select]()
   If e.Graphic.Selected Then
  MyDataGrid.ScrollIntoView(e.Graphic, Nothing)
   End If
  _lastGraphic = e.Graphic
   End Sub
   Private Sub MyMap_Loaded(sender As Object, e As RoutedEventArgs)
  MyDataGrid.Map = MyMap
  MyDataGrid.GraphicsLayer = TryCast(MyMap.Layers(1), ESRI.ArcGIS.Client.GraphicsLayer)
   End Sub
   End Class
End Namespace
there in new api we not have GraphicMouseButtonEventArgs so we got error
