Send Error - Code 1000 - Survey 123
7572
8
07-20-2016 07:32 AM
TravisKiel
I get this message when I am trying to upload by survey.  See attachment.
"Send Error
This survey was not able to be send due to the following error:
Code 1000
Incorrect syntax near '.'.
Must declare the scalar variable :@no".
Must declare the scalar variable "@_NewFeatureID_.
Travis
IsmaelChivite
Esri Notable Contributor
Ok. I found the problem.
In your XLSFile, in row number 40, you are defining the NAME of your question as No._Cull_Piles.  The period (.) is an invalid character in database field names, and that is causing the problem. Go back to your XLSFile and replace No._Cull_Piles with No_Cull_Pilles and life will be wonderful again.
IsmaelChivite
Hi Travis. Would you mind including your XLSFile so I can have a closer look?
TravisKiel
Here it is. Thanks so much
Travis
IsmaelChivite
TravisKiel
Thanks so much.
AlexNguepkap_Lemegne
Hi, I am having the same problem with my Survey.
I collected all the thd on the field, then when I am trying to send It on the web, "Erreur d'envoi Code 1000, incorrect syntax near '-' must declare the scalar variable "@nom_ecole_Menfoung"
Please how can I fix this problem without loose my data?
URGENCE PLEASE
JamesTedrick
Esri Esteemed Contributor
JenniferCarter1
I have a send error, the scientist can send his file when he is logged in. I have him as a publisher, I can sign in with my account (Admin) and I can send the file. I am not sure what settings are not checked for him to send?Send Error
JamesTedrick
Hi Jennifer,
Can you confirm that the submitter is signed in when submitting?  There is currently an issue that when going offline, the user is automatically signed off in iOS.  Otherwise, if the submitter has access to the submission endpoint (you shared the survey via the Survey123 website), submission should work.
