Data Access Module: Update Cursor (Not Updating Records)
4877
6
07-13-2016 03:08 AM
PeterWilson
I've written a Python function that is meant to update a File Geodatabase Table (Landuse) based on a Feature Class (Watershed). I'm using a Update Cursor  to update each field value where it finds a match within a Python Dictionary of HydroID and in return I use the "Shape_Area" as part of my calculations to update each field value.
There are eight landuse fields that I want to update using the same formula for each HydroID match:
  • Commercial_Forestry
  • Cultivated
  • Indigenous
  • Mines
  • Natural_Vegetation_Forest
  • Urban
  • Waterbodies
  • Wetlands
So instead of specifying each field through its index position manually, I step into a for loop and loop through each field updating the field value based on the formula. The problem that I'm having is that the Update Cursor is not updating the rows, although I'm calling updateRow() afterwards.
Is there anyway I can get around the following without having to specify each field through its index position manually?
# calculate percentage of landuse per watershed
def landuse_percentage(watershed, output_pivot):
    watershed_fields = ["HydroID", "Shape_Area"]
    valuedict = {r[0]: (r[1:]) for r in arcpy.da.SearchCursor(watershed, watershed_fields)}  # @UndefinedVariable
    landuse_fields = [f.name for f in arcpy.ListFields(output_pivot)[1:]]
    print(landuse_fields)
    with arcpy.da.UpdateCursor(output_pivot, landuse_fields) as upcur:  # @UndefinedVariable
        for row in upcur:
            keyvalue = row[0]
            if keyvalue in valuedict:
                print(keyvalue)
                for landuse in row[1:]:
                    landuse = (landuse*(30*30))/(valuedict[keyvalue][0])*100
                    upcur.updateRow(row)
                    print(landuse)
Python Code: for loop over each field
12366 (HydroID)
  • 0.962788133178 - (Landuse percentage based on Shape Area)
  • 62.0189203295
  • 31.8703202065
  • 0.123498273168
  • 13.8522293032
  • 1.24419729078
  • 1.02530804735
  • 2.19975286437
Python Console: Correct Values printed but table not updated.
        for row in upcur:
            keyvalue = row[0]
                row[1] = (row[1]*(30*30))/(valuedict[keyvalue][0])*100
                row[2] = (row[2]*(30*30))/(valuedict[keyvalue][0])*100
                row[3] = (row[3]*(30*30))/(valuedict[keyvalue][0])*100
                row[4] = (row[4]*(30*30))/(valuedict[keyvalue][0])*100
                row[5] = (row[5]*(30*30))/(valuedict[keyvalue][0])*100
                row[6] = (row[6]*(30*30))/(valuedict[keyvalue][0])*100
                row[7] = (row[7]*(30*30))/(valuedict[keyvalue][0])*100
                row[8] = (row[8]*(30*30))/(valuedict[keyvalue][0])*100
Python Code: specifying index position of each field manually.
Landuse: Updated Table using second Python Function
So any help how to loop through each each instead of having to manually specify the index position will be appreciated.
Luke_Pinner
MVP Regular Contributor
The built-in enumerate function is what you want:
        for row in upcur:
            keyvalue = row[0]
                print(keyvalue)
                for i, landuse in enumerate(row[1:], 1):
                    row = (landuse*(30*30))/(valuedict[keyvalue][0])*100
                print(row
Luke_Pinner
        for row in upcur:
            keyvalue = row[0]
                print(keyvalue)
                print(row
PeterWilson
Hi Luke
The following worked perfectly, thanks . Would you mind helping me understand why my original for loop didn't work as the printed results within the console were correct?
Luke_Pinner
Because you were modifying the landuse variable, not the row elements. Basically this is what you were doing
row = ['a','b']
for i, landuse in enumerate(row):
    landuse = landuse + "x"
    print landuse, row
ax a
bx b
PeterWilson
Hi Luke
Thanks so much, now I understand where I was going wrong, much appreciated.
XanderBakker
Esri Esteemed Contributor
Could you share a small part of your data to see if we can reproduce the problem? I would like to see what is happening...
For not having to specify the index manually you could do something like this.
for i in range(1, len(landuse_fields) + 1):
    row = (row*(30*30))/(valuedict[keyvalue][0])*100
... or perhaps you like the index of the field name in the list of fields better:
for fld_name in landuse_fields:
    i = landuse_fields.index(fld_name)
However, this is no explanation for not updating the fields in the updatecursor. I normally prefer not to overwrite values i the fields (areas to percentage), for problems that will happen when a script is run more than once
PeterWilson
Hi Xander
Thanks for the following, you are correct that I generally also don't update the original field values based on the calculations, due to bugs or errors. The landuse table that I have used is a output from Zonal Histogram that represents the number of cells for each landuse within each watershed. The following is generated within a separate function just before the following, so the risk of the values being overwritten is managed.
