Looping through layers in C#
2883
07-05-2016 11:29 AM
AndrewGehlot
Hello! This is probably a relatively simple question, but I am brand new to using the C# programming language and using ArcObjects.
I am attempting to change the default construction tool for many layers at once. I ran across the following code, which will update the construction tool for all classes within a layer, but I am trying to iterate through all of the active layers in my document. Are there any modifications I can make to do this? If so, how do I create an add-in button from this code? Thanks.
using System;
using ESRI.ArcGIS.Editor;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Framework;
namespace SetTemplateProperty
  public class SetDefaultTemplateTool : ESRI.ArcGIS.Desktop.AddIns.Button
    IEditor3 m_editor;
    public SetDefaultTemplateTool()
      m_editor = ArcMap.Application.FindExtensionByName("esriEditor.Editor") as IEditor3;
    protected override void OnClick()
      //get the current template and ArcMap tool
      IEditTemplate currentTemplate = m_editor.CurrentTemplate;
      ICommandItem currentTool = ArcMap.Application.CurrentTool;
      //loop through the templates in the edit session
      for (int i = 0; i < m_editor.TemplateCount - 1; i++)
        IEditTemplate editTemplate = m_editor.get_Template(i);
        if (editTemplate.Layer.Name == currentTemplate.Layer.Name)
          //set the default tool to the current ArcMap tool
          Guid g = new Guid(currentTool.ID.Value.ToString());
          editTemplate.Tool = g;
    protected override void OnUpdate()
      this.Enabled = (m_editor.EditState == esriEditState.esriStateEditing);
