how to get token to access a map service or feature service?
7443
06-24-2016 05:41 PM
BoYan
I would like to access mao services for example this one: http://earthobs1.arcgis.com/arcgis/rest/services/Live_Stream_Gauges/MapServer/ , if I type the url in browser, it redirects me to the arcgis online login, then I can access the map server. But if I want to access the map server using python code with the REST API, how do I get the token?
I also noticed that there are many ways to get the token, like using 'Oauth2.0 token' or 'generateToken'. I just don't know what I should use and what exactly is the url I need to use to get the token in this case.
RandyBurton
There is a link to some code in this blog article that gets a token: Using Python to push updates to a hosted feature service from an external source | ArcGIS Blog.  Here are the basic steps:
import urllib
import urllib2
import json
# Credentials and feature service information
username = '<username>'
password = '<password>'
URL = "<the services url you want to connect to>"
# obtain a token
referer = "http://www.arcgis.com/"
query_dict = { 'username': username, 'password': password, 'referer': referer }
query_string = urllib.urlencode(query_dict)
url = "https://www.arcgis.com/sharing/rest/generateToken"
token = json.loads(urllib.urlopen(url + "?f=json", query_string).read())
if "token" not in token:
    print(token['error'])
    sys.exit(1)
query_dict = { "f": "json", "token": token['token'] }
# query your services url
jsonResponse = urllib.urlopen(URL, urllib.urlencode(query_dict))
BoYan
thanks, I haven't tried your approach yet, but I figured that I can create an application in my developer account and use the app id and secret to get token for the rest api
JamalNUMAN
Legendary Contributor
How to enable token for a particular map service?
Jamal Numan
